cnc 4 to acorn wiring
- CNC Control System Serial Number: cnc4-md3-10-80v serial#1872
Hey guys received my acorn board today, have a question about wiring from micro1 input header to acorn ? Does pulse go to step , dir to dr , pwr to com , cpugnd to en. If not let me know the right wiring diagram. Thanks
Re: cnc 4 to acorn wiring
The connections would be below.
MICRO1 --> ACORN
PULSE --> ST
DIR --> DR
PWR --> EN
CPUVCC --> +5V
CPUGND --> COM
Remember that since those terminals on the ACORN are open-collector, you are going to want a pull-up resistor installed between those ACORN outputs and +5V. I would recommend either a 330 ohm resistor.
MICRO1 --> ACORN
PULSE --> ST
DIR --> DR
PWR --> EN
CPUVCC --> +5V
CPUGND --> COM
Thanks again.
Here is the schematic for Acorn to Micro1 drive.
- S14910-ACORN_rev3, CENTROID CNC4 MICRO1 DRIVE.pdf
- (91.7 KiB) Downloaded 132 times
