Tool Touch off selection has been added to the v4.12 Wizard i/o drop down list. Use the Wizard to set up the Tool Touch Off and probe inputs.
How to connect a TouchProbe and a ToolSetter at the same time
Re: How to connect a TouchProbe and a ToolSetter at the same time
Please post a current report from 4.12
If you have it handy, a report from 4.10 might be helpful as well
Here are the reports for 4.10 and 4.12.
Both probes work with both versions using the parameter settings therein.
- report_38D269594F9C-0110180512_2018-05-14_20-42-30.zip
- (183.45 KiB) Downloaded 147 times
- report_38D269594F9C-0110180512_2018-05-12_20-21-17.zip
- (250.87 KiB) Downloaded 124 times
This weekend I will also update to V4.12 and post the results of setting-up the probe and toolsetter.
Can the logic being discussed here be used for a lathe tool 'height' adjustment?
