42” manual Kondia’s evolution to allinonedc
- CNC Control System Serial Number: a900749
Bought this used Kondia mill about twenty years ago to help keep things working on the ranch. I eventually wanted to upgrade it but retain manual use characteristics. I bought some old Anilam parts stripped off an old Bridgeport and began adapting things to my mill- except my machine is generally metric.... nothing quite fits and the ball screws were for a larger machine...
. so adapt!!!!
Re: 42” manual Kondia’s evolution
Machine worked but the electrics eventually failed... Centroid to the rescue! I have used original servos, power box, transformer and caps along with some cabling. Room runs out quickly in this cabinet! Boring the servos for a 6mm shaft for the new encoders was the most difficult setup. Managed to mill the yoke to fit using the mill on itself.
Re: 42” manual Kondia’s evolution to Allinonedc
Machine is up and running! The assembly manual is fantastic! I had only a couple minor issues that were expertly answered on the support forum.
Re: 42” manual Kondia’s evolution to allinonedc
wow! nice work! and thanks for posting!
