I have a rotary table with and old DC brushed K&D MagMotor. I contacted the manufacturer and the only specs available are:
Ke ~ 28.3 volts/1000 rpm
Kt ~ 38.3 oz-in/amp
Rt ~ 0.90 ohms
Attached is a photo of the motor nameplate. I was hoping this would work with my ALLIN1DC control. Liviu or Keith please tell me it will work
Motor compatible with ALLIN1DC?
Re: Motor compatible with ALLIN1DC?
That motor should be fine. You'll need to watch your bus voltage though and may need to change the encoder.
From what little info I could find they list bus voltage at 12-120VDC. I couldn't find any info on the encoder installed.
https://magmotor.com/brushed/c40.pdf
What bus voltage are your other motors running? Will this be an upgrade to 4th axis?(DC1) If so, the DC1 can run at a bus voltage other than the ALLIN1DC.
Thanks, Scott. This will be a DC1 addition and I didn't know the DC1 could run at a different bus voltage. Everything else will be at 155V (rectified 115V) without a transformer. I'll probably change out the motor since I really don't want to add a transformer and the encoder is only 1000L so I'd have to change it anyway.
