CNC10 cannot load files
luiguicam
Post by luiguicam »
Hello,
Please help, I had to replace the computer since the old one died. Now the new computer works pretty well but it doesn't recognize the netwok card or the USB devices, so i Cant load files into the memory. Any Ideas?
Regards,
diycncscott
Re: CNC10 cannot load files
Post by diycncscott »
We need a report file (even an old one since your usb isn't working), serial number and/or System Id in order to help.
Does the computer you installed contain the EXACT same motherboard that was in the previous system? Did you replace the SSD as well? Did you purchase it from Centroid? What version of CNC10 are you running?
Linux Kernels are VERY sensitive to hardware changes. If your current motherboard is not and EXACT replacement, it is likely that it has chipsets that didn't exist when the Kernel was released and are therefore not supported.
