Huan Yang VFD Parameter Settings
Posted: Thu Sep 07, 2017 11:13 am
Centroid has a schematic to wire up the HY VFDs. Attached are the VFD BASE parameter settings to help get you going if you follow that schematic.
As with any VFD, there are MANY parameter settings to fine tune it to your application. You will have to read the manual, which isn't that terrible.
Remember, the Acorn schematic set can be found here: http://www.centroidcnc.com/centroid_diy ... oller.html
