is 3.04 still available?
_______________________________________________________
LOGIN below to POST your questions and comments on AjaxCNC products.
lauyder
System Serial Number: A900104
Post by lauyder » Tue Jun 13, 2017 2:58 pm
The motherboard on the computer I was using up to now gave up the ghost, so I got a newer one. problem is I used to use cnc3.04, now I have to use 3.16. that and now only having 3.5 gb ram is the only difference in the machine but she goes wacky on me when moving two axis at a time. I've gone into parameters to slow multi axis move speed down to a speed that it can handle it when jogging but it still goes wacky running a cycle. says one on the encoders out of position. I noticed when it shut off, federate was set as ipr. why is that? anybody had that problem?
Centroid_Tech
Re: is 3.04 still available?
Post by Centroid_Tech » Wed Jun 14, 2017 10:32 am
Yes, you can still install CNC11 v3.04 if you wish but I would recommend against it. If you provide me with your email address, I can email it to you. Personally, I don't think that is your issue. The CNC11 software defaults to a Feed per Revolution, G99, state. If the feedrates in your program are not Feed per Revolution but rather Feed per Minute then you should have a G98 at the beginning of your program.
Who is online
Users browsing this forum: No registered users and 4 guests
