broken tool T1. re-ref tool & T1 measure knee confusion.
countryguy
System Serial Number: none
Post by countryguy » Thu Apr 13, 2017 2:33 am
I know .. I know. I have watched the Video on knee-mill's and tool offsets thrice now. :oops: I finally broke a measured offset tool! T1 and need to get that offset back in asap. Per vid, it seems I need to remeasure Tool 1 against the ref tool but am confused. I set in the Ref tool and increment to the same spot atop the vise. Then I put in the new tool1 and re-measure (F2) on the T1 tool. Is that right? What gets me is that I know the Knee is in a different spot than the original T2,t3, to Ref measurements were. It feels like I am accommodating that difference of Knee by my increments up or down to the top of the vise to get the Ref tool distance setup for a T1 remeasure. I keep trying to wrap my head around this? Won't my new tool1 via a new F2-measure, be higher or lower in a stored Z offset value compared to those of the previous ref/T2,t3 measures? So close to getting this I think... Can you help get me thru this and I'll be on my way today.
Re: broken tool T1. re-ref tool & T1 measure knee confusion.
Post by cncsnw » Thu Apr 13, 2017 12:44 pm
The net result of the standard procedure is that you are measuring your T1 (T2, T3) offsets compared to the length of the reference tool.
That is the whole point (the only point) of keeping a designated reference tool.
That is what you are doing when you use the reference tool to set Z Reference on some surface, before you measure tools using that same surface: allowing the control to see the difference in length between the reference tool and the measured tool.
countryguy
Post by countryguy » Sat Apr 15, 2017 9:15 pm
ok. I will check the manual for some more detail. In the vid, seems there is a comment about simply reloading the reference (which I have). Was not sure if I was supposed to "F1" that or not. I'll figure it out.
Post by cnckeith » Tue Apr 18, 2017 2:52 pm
maybe thinking about it this way will help....when using a reference tool method.. all you are doing is using the cnc machine as a fancy measuring device. the tool height offset value "H" is simply the difference in length between the reference tool and the actual tool. so you could also just measure the difference in length between the reference tool and the tool and type that number in the height offset value for that tool and you would be all set.
when setting an arbitrary reference position using a reference tool.. all that position is ...is to let the control know that you will be touching both the reference and the tool off that spot..so the control measures the additional (or less) distance moved with the tool to touch the same spot as the reference tool. that movement is the difference in length between the two.
most people make this out to be much more complicated that it is by confusing part zero and a z tool reference position which have nothing to do with each other.. so separate these three z locations... Z home, Z0 (wcs) and reference position in your thinking and it will all start to make sense.
Post by cnckeith » Tue Apr 18, 2017 2:54 pm
graphic shows difference in height between reference tool and actual tool when touching the reference position.
Who is online
Users browsing this forum: No registered users and 2 guests
