Disable PLC faults
Disable PLC faults
Still trying to set up Allin1dc 3.08 control. Im at the disable PLC faults stage and I pressed alt I ,then arrow key to the 7th red dot I want to invert press ctrl alt and I all together and nothing happens it wont change to green . I moved to different dots and try to change them and nothing. Any ideas ???
Re: Disable PLC faults
In order to use the ctrl-alt-i functionality your PLC program needs to support it and you need to be using v3.14 of the software as well as . If you are running a basic PLC program, you can update from the link below and choose to install a new basic PLC program during install. :
http://ajaxcnc.com/tech/downloads/softw ... /index.php
That did it !! Thanks Scott
