Is there a wiring diagram for the ALLIN1DC to the GS2-XXXX
There are wiring diagrams for the GS2 to the GPIO4D in the respective install manuals
But not for the ALLIN1DC to GS2 Spindle Inverter that i could find. (drawing is for the SJ100)
I see the similarities, If I assume some pins are in common from GPIO4D and the ALLIN1DC
OUT5, OUT7, OUT8, IN10, COM9 -12 Same from GPIO4 and ALLIN1DC (?)
Clarification (or Drawing) needed for:
12VDC and 12 COM : is this external supply voltage to the GS2, or does this come from the ALLIN1DC?
Spindle Analog (A1), Spindle Analog Com(ACM), where do these input/outputs goto on the ALLIN1DC?
Thank you.
GS2-XXXX ALLIN1DC
- CNC Control System Serial Number: 0916130849
Re: GS2-XXXX ALLIN1DC
Would it help to see the Hitachi WJ200 2.2kw connections to the AllInOneDC?
Mikie in Bloomington IL
- CNC Control System Serial Number: A900360
It just might.
Can you provide a link to it please.
Thanks you.
Thanks you.
Looking at the connections for the SJ200 did not help.
Not the same as the GS2.
Please see the attached schematic for wiring between the GS2 and ALLIN1DC.
- allin1GS2.pdf
- (67.44 KiB) Downloaded 273 times
