Encoder Basics
BigWillieStyle
System Serial Number: none
Re: Encoder Basics
Post by BigWillieStyle » Fri Jan 05, 2018 1:03 am
Question
Lead, Pitch, TPI all refer to different things but numerically are all equivalent?
*Note in below example TPI is actually 5.08 according to my arithmetic.
5mm Lead = 5mm Pitch = 5 TPI*
Is this correct?
frijoli
System Serial Number: none yet
Re: Encoder Basics
Post by frijoli » Fri Jan 05, 2018 7:12 am
woffler wrote:
Tue Jan 02, 2018 2:11 pm
Hi all ,i have a 16 bit encoder differential driver receiver it says on my servo motor for my spindle ,with A+A-,B+B-,Z+Z- it is a 1.8kw servo motor from DMM tech that i use on my lathe .
I was wondering if it would interface with the Acorn board ?
The DMM servo encoder out will work with Acorn.
Clay
Clay
near Winston-Salem, NC
unofficial fb group https://www.facebook.com/groups/897054597120437/
woffler
Re: Encoder Basics
Post by woffler » Fri Jan 05, 2018 4:00 pm
Thanks for the reply Clay
System Serial Number: 100505
Re: Encoder Basics
Post by tblough » Fri Jan 05, 2018 4:39 pm
Question
Is this correct?
BigWillie, lead and pitch are the same. TPI is not - it is the inverse of the others. A 0.2" pitch is 1/0.2 = 5 TPI.
Pitch is how far a screw advances in one turn. TPI is turns per inch. So if one turn moves 0.2 inches then 5 turns move one inch. Metric screws are normally specified based on pitches. Imperial screws are classified on turns per inch.
Your example gives the false impression they are equivalent only because 5mm is close to 0.2" but not exactly. 5/25.4 = 0.19685“. 1/0.19685 = 5.08 turns per inch.
DICKEYBIRD
System Serial Number: n/a yet
Re: Encoder Basics
Post by DICKEYBIRD » Sun Jan 07, 2018 9:41 am
Remember that the servo motor must drive your spindle at a 1:1 ratio...no belt reduction.
Milton in Collierville, TN
Re: Encoder Basics
Post by cncsnw » Sat Jan 13, 2018 8:00 pm
tblough wrote:lead and pitch are the same. ...
Just to be pedantic here:
- Lead is how far a screw advances in one turn.
- Pitch is the distance between successive thread crests.
- They are the same for a single-start thread (the vast majority of threads you will encounter).
- They are different for multi-start threads: lead = pitch * number of starts.
BigWillieStyle
Re: Encoder Basics
Post by BigWillieStyle » Sat Jan 20, 2018 3:00 pm
Thanks tb, I appreciate the clarification. Also with regard to encoders, through some additional reading I found a diagram via Dynapar as being a helpful tool for those less familiar, like myself, to delineate the semantics of encoder classification.
http://www.dynapar.com/uploadedFiles/_S ... _29_13.pdf
To the experts, please confirm or correct my assertation with regard to the correct encoder type.
Who is online
Users browsing this forum: aamir and 1 guest
