hi
when i start the machine and press cycle start:
1: Z axis homes correctly
2: X axis homes correctly
3: Y axis moves slowly making bizarre noise.. then it either
- homes without traveling the whole distance to the limit switch (several inches before it even touches the limit switch)
- or it homes without traveling the whole distance, then stating an error (something like there is a difference in the new home to the old - accept Y/N - contact centroid)
before homing i can move the axis
also i can move the axis after homing (then they run faster - why?)
i bought the motors pre-cabled.
there is no slip on the ballscrew and motor - all tightly screwed.
so what can be the causes?
wrongly tuned motors?
do i have to uncouple the y axis motor and turn the ballscrew a bit so it its in a different position?
thanx for narrowing it down for me
best
david
**RESOLVED** :) homing Y errors
- CNC Control System Serial Number: A50383
Re: homing Y errors
when i do the homing with the homing function - one axis after the other - it works
so i'm clueless why it does not work at the beginning with cycle start
Re: homing Y errors
Can you please confirm you are using mac3 or CNC10
Re: homing Y errors
If you are using CNC10 or CNC11 following step should be checked
1) Wiring of the Index pulse i.e Z and /Z go in F1(setup)--->F3(config)---->F4(PID) you see the following screen
Now index pulse should come once in a revolution if it show Z* constantly then you must swap your index pulse wires i.e Z---->/z
and /z--->z
Please Set parameter 148 to 1 will enable fast Jog before homming
and /z--->z
Re: homing Y errors
dear cnc-global
i'm on a cnc10
you are talking about Z axis, although the homing of my Y axis has quirks..guess it's a mixup
i did go into the PID setup
the axis do NOT show an asterisk * constantly when i move the axis.
if i understand you correctly the asterisk should blink once per revolution.
what i find bizarre is:
when i move my axis, all of them, the asterisk blinks. but not regularly..it seems to skip its beat, although if i move the table at a constant speed it should blink at a constant beat, right?
if you talk about the index pulse wires..are you talking the physical wires on the motor encoder? because i bought the motors new prewired - i'd be shocked if ajax made an error in wiring these.
i'm so close - only the y axis has to home automatically and i'm ready to go, but i'm afraid to do something wrong as i already fried one servo drive once
thank you for additional help
i'm on a cnc10
Re: homing Y errors
Ya i m sorry by mistake i typed Z-axis
IF Motors are prewired then their is no issue for wiring i m 100% sure
ok Now check the Limit switch page
F1(set)--->F3(config)--->F2(Mach)---->F2(Motor)
Kindly check the Home Limit switch set properly
Also which direction machine will home M92/y or M91/y
It seems to me your home switch set on zero or any other value of the input that is apparently low
Kindly update
Kindly update
Re: homing Y errors
i will check again..although i think i had this covered in my last post.
http://www.ajaxcnc.com/ajaxbb/viewtopic.php?f=20&t=299
i mean if it is wrong why would homing via the homing setup (individual axis) work but not after startup?
it's like the motor crawls in the right direction (-Y) but stops after an inch before even touching the limit switch wich is 5 inches away
Re: homing Y errors
homing sequence is
1. M92/Z
2. M26/Z
3. M91/X
4. M26/X
5. M92/Y
6. M26/Y
1. M92/Z
2. M26/Z
3. M91/X
4. M26/X
5. M92/Y
6. M26/Y
Re: homing Y errors
plz send me the picture of the screen of limit switch
Re: homing Y errors
it's still like this:
