ACORN - REAL-TIME feed rate adjustment from spindle RPM
ALVARO
CNC Control System Serial Number: 171025
Post by ALVARO »
Hello!
getting ready to convert to ACORN from my mach3 kASUGA knee mill conversion-
is it possible with Acorn to sense spindle RPM and then adjust feedrate acordingly (with some math)?
thank you!
frijoli
Re: ACORN - REAL-TIME feed rate adjustment from spindle RPM
Post by frijoli »
Feed per revolution!
If you have an encoder on the spindle it works like a charm!
Clay
near Winston-Salem, NC
diycncscott
Post by diycncscott »
Yes. Parameter 78 can be configured to either wait for the spindle to each programmed speed before axes move and/or adjust the axes feedrate up/down as the spindle slows or speeds up due to load conditions
