OAK Custom control panel using 11077 connector?
Posted: Mon Feb 12, 2018 2:37 pm
Do you have any more information on the optional 11077 control panel connector on the OAK board? I would like to create a custom panel with individual switches and wire them to utilize the control panel connector on the OAK board. Also, using the existing connector will make for a cleaner install.
I have downloaded and looked at the wiring diagrams. There is a drawing for the 11077 control panel, but it does not specify the connector used or the factory used pin-outs.
Reference data on mating connectors for the other board connectors would also be appreciated.
