lathe C axis code sample? Centroid < answered >
frijoli
System Serial Number: none yet
Post by frijoli » Wed Jan 03, 2018 10:11 pm
Are there any samples of C axis code fore Centroid controls. I am finding lots of examples that don't work, but none from actual Centroid machines. Centroid doesn't accept G17-G19 so I am confused on how Centroid intends it to be done.
There is nothing in the manual showing programming of wrapped tool paths nor face tool paths.
I did manage to write a post processor, in which I generated a program through Fusion 360 and generated a tool path that I believe will work.
Unfortunately it runs REALLY slow when using the c axis. I know why it's slow, but I don't know how to correct it.
So can anyone point me to some code?
Clay
Clay
near Winston-Salem, NC
unofficial fb group https://www.facebook.com/groups/897054597120437/
Re: lathe C axis code sample? Centroid
Post by cnckeith » Thu Jan 04, 2018 12:23 am
clay, the reason its slow is the feedrate on the c axis program line is that the F command is in degrees per minute for a rotary axis.
so for example...
G1 Z2C3600 F2 that means the C axis is going to go 10 revolutions at 2 degrees per minute while the Z axis is interpolated to move to 2.0000 from the position it is at to 2.0000 in the time it takes for the C axis to rotate 10 times at 2 degrees per minute. (very slow)
Gary Campbell
System Serial Number: C8FD19D3C3E1-1109170238
Post by Gary Campbell » Thu Jan 04, 2018 1:01 am
Clay...
I have no idea how you get it into a Fusion postP, nor the syntax for math function in the Centroid controller, but what I have used in the past to get a realistic feedrate (matching XY) for a rotary axis is:
115 * ({desired surface feedrate} / {diameter})
frijoli
Post by frijoli » Thu Jan 04, 2018 7:43 am
Clay...
Thanks Gary. What does the 115 represent? Also, how does that work when switching from rotary to straight lines? I assume you are programming this line by line as opposed to canned cycles?
Clay
Clay
Gary Campbell
Post by Gary Campbell » Thu Jan 04, 2018 9:45 am
Clay...
Round numbers for 114.59 or 360 / pi
cnc_smith
Post by cnc_smith » Thu Jan 04, 2018 11:07 am
Clay,
I have attached a sample g-code program for C-axis for the Centroid lathe. This has the feed in degrees per minute. When X or Z are moving without a C-axis move on the same line of G code the feed rate (F) is in inches per minute. This program uses the M51 and M50 to turn C-axis on and off and the M23 and M25 to turn the live tooling on and off. ( If you are using different M codes for these functions you will have to change this program to those M codes to graph and run this program). This is the same part that is shown on the Centroid website. http://www.centroidcnc.com/cnc_c_axis_lathe.html
there are photos of the part and go down to the bottom and there is a video of the part being machined.
To use a third party post processor you'll need to set the CNC Controller type for the feed to Feed in degrees/minute.
C_AXIS_EXAMPLE_1.txt
I changed the file extension from .cnc to .txt to attach the file. Centroid will run this program with the .txt extension.
(16.27 KiB) Downloaded 15 times
frijoli
Post by frijoli » Thu Jan 04, 2018 11:53 am
Clay,
Outstanding, Thank you!!
Clay :D
Clay
Who is online
Users browsing this forum: No registered users and 2 guests
