OAK Enable Axis
Posted: Mon Dec 18, 2017 11:37 am
by tblough
I'm trying to commission my drives on my lathe conversion and before I broke out the jumper wires to turn on the drive enable, I was wondering if there was an output bit or memory location I can force from the I/O panel in CNC11v3.16 to turn on the drive enable for Axis 1 and Axis 2?
Re: OAK Enable Axis
Posted: Mon Dec 18, 2017 6:01 pm
by Centroid_Tech
Unfortunately, the PLC program doesn't control those outputs so there is no way to force them. They are handled by the CNC11 software. You should just be able to press F3(MDI). That will energize all of your axes. If you don't have things wired in such as axis encoders or fault signal or etc. which will put the Centroid control in a fault state, you should be able to disable stall detection. From the main screen press F1(Setup)->F3(Config)->default value is 137->F4(PID). Press CTRL+V. You should see a message telling you that stall detection has been disabled underneath the message window. Then you can press F3(MDI).
