Hi
I want control a spindle with below specification:
AC motor
24000 Rmp
3 phase AC
800 HZ frequency
16KW power
Can i control this spindle with DC3IO or GPIO4D ? or your kids have any solution for this problem?
This spindle need a driver for controlling .
Thank you
**RESOLVED** Quetion
Re: Quetion
SML,
You need to find an inverter with the appropriate spec's to run your spindle motor. Then you can interface the DC3IOB or GPIO4D with the inverter (FWD, REV, analog signal etc.). The control will control the inverter and then inverter will control the spindle motor.
Ajax_tech
Ajax_tech
Re: Quetion
Hi Mr.ajax tech
I am happy that ajax kid able to solve our problem.
Thank you
Thank you
