**RESOLVED** Plot question
Locked
Riley
Post by Riley »
My plot lines are just flat lines. The motors are quiet, and movement is smooth and accurate but the plots I'm getting are strange. There is no ramp up or down. I have tried hiding different line but the results are the same. Have also reloaded brains, any ideas?
diycncscott
Re: Plot question
Post by diycncscott »
Hello Riley,
You will need to scale your values. There are some suggestions for which data to show/hide and what scaling factor(s) to use in the Ajax Mach3 Operators manual.
For the most part, the only fields that you need to make visible are absolute error and absolute/expected velocity
Riley
Re: Plot question
Post by Riley »
My bad, was not hittting the "plot" key fast enough. Hitting the key right after movement stops I get a good plot.
Locked
