Running backwards (resolved)
Anthony
System Serial Number: (0616102337)
Post by Anthony » Thu Nov 30, 2017 12:55 pm
When I push x-label goes left y+ table moves foward .120 vac I just purchased used any help?
Centroid_Liviu
System Serial Number: none
Re: Running backwards
Post by Centroid_Liviu » Thu Nov 30, 2017 1:04 pm
Please attached a current report of your system. From the Main Menu Press F7 Utilities, and then F7 Report.
viewtopic.php?f=60&t=1043
Post by martyscncgarage » Fri Dec 01, 2017 12:18 pm
What controller are you using? Acorn, All in One DC Oak?
Need more info on your setup.
Centroid Liviu asked for your report file, here are instructions to generate it:
viewtopic.php?f=60&t=943&p=4312&hilit=report#p4312
"Jack of all trades, master of none!"
Centroid_Tech
Post by Centroid_Tech » Fri Dec 01, 2017 12:30 pm
Based on their serial number of the control, this is an old Centroid CNCDRO control. It sounds like the control wasn't properly setup but that is why we need a current report from the system to see how the system is setup.
Post by martyscncgarage » Fri Dec 01, 2017 12:37 pm
My apologies. You were providing HIM with a report you had on file.
Anthony
Post by Anthony » Fri Dec 01, 2017 12:50 pm
Thanks I fixed the axis moving backwords.
It is a cnc10 I tried to create a report like in the video but that is windows and this is not . It's on a used kneemill that's about all the info I have .or can locate at this time .
It had a dead cmos batery and now I'm in demo mode any sugestions?
Centroid_Tech
Post by Centroid_Tech » Fri Dec 01, 2017 1:25 pm
A dead CMOS battery shouldn't cause the control to be locked out of the CNC10 software. Please email us a current report from that system. Whether you have a Windows or Linux or DOS system, generating a report is pretty much the same. The only time it's different is on the older DOS systems because either the report function didn't copy all of the necessary files or the report function wasn't even supported. Perhaps the attached tech bulletin will help in generating a report.
193 Generating Report.pdf
(5.58 KiB) Downloaded 4 times
Anthony
Post by Anthony » Fri Dec 01, 2017 2:54 pm
I attached the files
report.txt
(92.34 KiB) Downloaded 5 times
report.zip
(29.66 KiB) Downloaded 4 times
Centroid_Tech
Post by Centroid_Tech » Fri Dec 01, 2017 4:26 pm
Looking at the report, you do have permanent unlocks entered. Please verify that on the Options, it shows Permanent Unlock and Intercon as highlighted in green and that they say ON to the left of the option. If it does, then you have nothing to worry about as when the DEMO expires, those features will remain on. The report shows that it was generated on January 3, 2009. Please make sure that you correctly set the date and time in the BIOS settings. You can get to the BIOS settings by pressing the DEL key as soon as you power the system up.
Anthony
Post by Anthony » Fri Dec 01, 2017 5:12 pm
Thank you for your help :D
Who is online
Users browsing this forum: No registered users and 2 guests
